Using saved sets
Many Vectorworks dialog boxes allow you to save the current settings so that they can be quickly applied again.
To use saved sets:
Open the object's preferences or settings dialog box.
The top part of the dialog box offers options for saved settings.
Parameter
Description
Settings
Displays the name of the current saved set; to use a different saved set, select it from the list of saved sets available for the object.
Any set in the list with angle brackets indicates either a Vectorworks default set or a set that hasn't been saved. For example, <Active Settings> or <Custom Settings> refers to the dialog box's current parameters, which are not saved as a set. <COBie Defaults> is an example of a default set provided by Vectorworks.
Open
If available, opens a dialog box to locate and load saved sets from a local or network location
Save
Opens the Save Settings dialog box to name and save the current parameter settings; the saved set is added to the Settings list
Manage
Opens the Manage Saved Sets dialog box, to rename or delete saved sets. Select a name from the list, and then click the appropriate button.
When renaming a set, if the entered name is already assigned to another set, you're prompted to confirm that you want to replace the existing set.
